02 Si ECu
Old Feb 11, 2008 | 04:56 AM
bbspell22's Avatar
Default 02 Si ECu
anyone know if this needs a reflash when doing a K20a3 in a 02 ex? I know when swapping the a2 it needs a reflash coming from the RSX, but no one has posted anything about the a3.
Old Feb 11, 2008 | 01:05 PM
SovXietday's Avatar
Default RE: 02 Si ECu
Nope, it's the correct ECU. If it's modded he might want a reflash though, certainly can't hurt.
Old Feb 11, 2008 | 02:11 PM
bbspell22's Avatar
so the ecu should work without a reflash? I know the K20a2 needs a reflash when swapping it into the 02ex. Do You know if the rsx subframe and cv axles from the Si are still needed for the swap, or will that engine just drop in and the si mounts will work?
Old Feb 12, 2008 | 06:43 PM
SovXietday's Avatar
I have no idea about the swap itself, don't plan on owning either car so never really went in and researched it.
K20A3 IS the engine in the 02 Si, so yes the ECU from the 02 Si will obviously work just fine.
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
