2000 SI Rev limiter
It wont make anymore power if you remove it. At a certain point it makes peak hp and just holds it throughout the band. Like for example a car that makes 230hp@5300rpm. Its peak is 230hp. Not even if you raise the revs will that peak power change. Its a civic it is fine the way it is. Dont see the point in changing it. It just as bad as changing the vtec point from stock.
Just my opinionated 2cents
ORIGINAL: 2KCIVICSIG
you guys are lucky in the states, we get B16A2 only in SIR civics which are pricey here.
