97 EX ECU & OBD Swap
Old Oct 5, 2008 | 09:54 AM
rags2richs's Avatar
Default 97 EX ECU & OBD Swap
97 Civic EX-megan 4-2-1 header, WS2 exhaust system, AEM SRI. I would like to upgrade my ecu & obd but I dont know which ones I should be looking for, could you guys offer some direction. Will this throw off my fuel mileage or make me start throwing codes if I change my ecu & obd, and can I expect any noticeable gains if I do this.
Old Oct 5, 2008 | 10:34 PM
you need an OBD1 P28 ECU (the one D16Z6 uses) and a obd2-obd1 conversion harness
The ECU needs to also correspond to your transmission.
it'll work fine
You won't see any gains unless you chip it (a real chip, like phearable.net chips... not the ebay ones), but the gains from that will still be very minimal.
you can buy the ecu harness and the chipped ecu at phearable.net and tell them what you have. You might get a tiny bit of gains (unnoticeable), but not really much because you just have bolt ons.
the ones from phearable are all for manual transmission, btw
personally, i'd take that money and get a magnaflow direct fit high-flow catalytic converter instead on summitracing.com
you'll probably see more gains from that than a chipped ecu/OBD1 swap
BcBaudoux
Mar 20, 2010 12:57 PM
JosephAdam22
Jul 24, 2008 05:38 AM
SoCaL.rider
37
Nov 26, 2007 10:28 AM
WHISP63
Oct 24, 2006 11:04 AM
