99 Catalytic Engine light question
Old Nov 2, 2006 | 07:29 PM
ClayMayTion's Avatar
Default 99 Catalytic Engine light question
Hey guys, I thought i would try and ask anyones opinion on here this sites great. Ok i have a 99 ex and awhile back i bored out my cat but did not do the disconnect battery for 5 mins then replug it and let the car idle for 5 mins so the computer adjusts the air/fuel ratio. So a little down the road my engine light came on and had it checked out and they said its emissions like i figured. My question is do i have to replace my 02 sensor, is there anything i can do to get my car running normal? It doesnt seem to get the 34ish mpg it used to get when i first bought it, although it does have 115k miles on it now.. Any responses will be appreciated. Thanks!- Clay
Old Nov 4, 2006 | 05:50 PM
MY99SI's Avatar
Default RE: 99 Catalytic Engine light question
put a stock cat back on it and that will fix the problem, or a aftermarket high flow (with the high flow the check engine light will stay on still b/c it flows more than what it like is to so it says that theres a problem b/c it dosent knowwhats goin on (the ECU))
Old Nov 5, 2006 | 09:46 AM
I know i should just buy an oem one from anyone. ANy good suggestions on where to find one? Places usually want around 300 bucks for one. - CLay
Old Nov 10, 2006 | 06:55 PM
FlipHKD720's Avatar
get an o2 simulator, it tricks the engine into thinking the exhaust flow and emissions are perefect, when in reality you can have an exhasut system on. Read about it and order one for like $25 (get the universal one) at: www.o2simulator.com
gilbroyer
Jun 20, 2007 04:37 PM
wjelmer
Feb 4, 2007 09:01 PM
Mr99ciVicSI
Feb 21, 2006 09:49 AM
Civic98ex
Jan 6, 2006 11:24 PM
IBleedBolts
Feb 21, 2005 04:27 AM
