bin file
Old Dec 5, 2011 | 11:24 AM
eidde's Avatar
Default bin file
my grandson as purchased a 1995 prelude and we have problems I would like to find a stock bin file i believe is a AWL the putor has been chipped and chip modifiyed i would like to start over with a stock bin if I can get one thanks in advance eidde,,
Old Dec 5, 2011 | 11:56 AM
Welcome to the forum.
What is the string of numbers/letters on the side of the ECU?
If the ECU is chipped, do you know what program is on the chip? From my understanding, anything except Hondata cannot be changed without a tuner making the changes. If you have a Hondata S300 by some chance, I can send you a file for the H series motor that I am using on my H22 swap.
Old Dec 6, 2011 | 07:53 AM
eidde's Avatar
cr99
First off the car is a 1996 honda civic the engine has been swapped to a 1995 h22, has been changed to obd1 (as i read in one of your posts it will not pass the E test)..The puter is a PO6 modified to P28 so the info on the side of the ECU wont help,,,there is no info on the C256 chip its self ..I read the chip in tuner pro, discussed what i read with my grandson at this time he tells me it was use for racing the quarter mile...thats why I need the bin file to start from the begining ,,I have been tuning GMs OBD1 using Moates & Tuner Pro for many years . If we have to get Hondata I will ..would like to try the file first too much money invested to give up..Thanks eidde from the great north
Old Dec 6, 2011 | 08:06 AM
Sounds like a similar set-up. 99 Civic with OBD1 H22 swap running on a chipped P28.
I wish I could help more with the chip, but I only have experience with the S300 system, and I bought the S300 chip already installed in the P28, so my knowledge on installation lacks as well.
Old Dec 6, 2011 | 08:50 AM
eidde's Avatar
I was under the impression you had a bin file you could send me. I know what to do once i have the bin file..eidde
Old Dec 6, 2011 | 08:55 AM
I am not sure what a BIN file is. I am not sure of the file extension that S300 calibrations are set as. If you want me to send the file to you, PM me your E-mail address and I will send it tonight when I get home from work.
Old Dec 7, 2011 | 05:39 AM
eidde's Avatar
__________________
Above is what you said in an earlier post , this is what i would like you to do if possible ....I sent you my email address thanks ..eidde,
ksrecon
Jul 16, 2007 12:10 AM
siccdawg
Jul 22, 2005 02:33 AM
