check engine light! Help!
Old Nov 18, 2007 | 07:24 PM
tano001's Avatar
Default RE: check engine light! Help!
hmmm well I will try tom morning but last week when honda changed my oil they checked battery and said its good so maybe that solves that. but if its the alternator theres no way to start it to drive it 2 miles right? I might have to tow it and about that CEL i hope it aint the tranny
Old Nov 18, 2007 | 07:34 PM
A blown fuse #15 would affect proper alternator function and potentially lead to discharging of the battery. As I believe that you mentioned noting some improvement after replacing fuse #15, then this is real possibility. Also, assuming a faulty alternator (which I am unsure about), it may still provide sufficient charge to drive the car (turn all accessories off). Good luck.
Also, regarding the tranny code, did you notice whether the D4 light in the gauge panel was blinking, in addition to CEL being ON?
Old Nov 18, 2007 | 07:41 PM
Pete's Avatar
If its only two miles you could try to charge the battery by hooking jumper cables up to a running car for a hour or so..............then you should be able to go a few miles.
Old Nov 18, 2007 | 07:42 PM
tano001's Avatar
yeah the d4 was actually blinking as well I didnt pay attention to the length of time it was though. Well the first time this all happened I parked car and left it for awhile then I switched fuse and started to park it in my garage and the tranny seemed fine no lag no holding me back or anything but the lights were still dim.
Old Nov 18, 2007 | 07:48 PM
The blinking D4 light and the CEL code are both signaling a tranny problem. Your dim lights are a separate problem, likely either your battery, cables, or alternator.
Can I assume that after you changed fuse #15, your speedometer problem resolved?
Old Nov 18, 2007 | 07:58 PM
tano001's Avatar
$hit! not the tranny........... and about the speedometer I completely forgot to look at that hopefully my car will start tom and i will check but I am so pissed off because all this happened out of nowhere
Old Nov 18, 2007 | 08:15 PM
Considering that you haven't noticed any functional problems with the tranny, the CEL and D4 codes hopefully signify a less worrisome electrical problem. Anyway, good luck with the repairs.
Old Nov 18, 2007 | 08:32 PM
tano001's Avatar
thank for all quick responses and now that i think of it i hope the auto start doesnt have nothing to do with it cause i heard alot of complains abut those things
Old Nov 19, 2007 | 05:14 AM
tano001's Avatar
nope doesnt start and its making a cranking noise and with my luck its raining in my part of town.
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
fastncrazy1
Jan 4, 2010 05:55 PM
Benny Sim
Jul 19, 2005 07:43 PM
