civic ecu question
Old Apr 26, 2006 | 06:51 PM
greencivic's Avatar
Default civic ecu question
i just bought a 1989 civic with a b-16 runs real good and is fast but the person i bought it from said it has the wrong ecu that it has one for a 1989 civic si but i will work and the the v-tech is controlled by a swith on shifter my question is this this affect it in any way should i worry about putting in the right ecu .another thing is that they got the fan hooked up direct to battery i want to know if any has any info on how i can hook it back to stock .thanks for you'retime i can appreciate any comments
Old Apr 27, 2006 | 03:09 PM
jwsimons's Avatar
Default RE: civic ecu question
it would be a good idea to get a vtec ecu.. a p28 or p30 would be best, but then you have other wiring issue's... as for the fan, its controled by a sensor on the rear of the block... does your car have an aftermarket temp guage? the sensor was probably removed to install the gauge
Civic Si 00
Dec 30, 2010 10:44 PM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
