Dad Needs HELP With Daughters CAR
Old Jan 14, 2007 | 10:40 PM
mxs's Avatar
mxs
Default RE: Dad Needs HELP With Daughters CAR
ORIGINAL: shopmanual
Yeah if it was running on a B16A2 ecu it would be dumping on too much fuel because that engine is DOHC and has more airflow, so probably needs more fuel to maintain the proper fuel to air ratio.
well supposedly it has a B16A2 engine......
Old Jan 15, 2007 | 12:51 PM
Kedawei's Avatar
Whoa now, engine should say D16Y8. This is an EX, not a Si.
Old Jan 15, 2007 | 12:55 PM
mxs's Avatar
mxs
ORIGINAL: Watt
I purchased my Daughter a 1999 Honda Civic EX
the engine had been changed (we knew this at purchase)
The EX engine was replaced with an SI engine
Old Jan 15, 2007 | 01:48 PM
Kedawei's Avatar
Gotcha.
Old Jan 15, 2007 | 08:39 PM
Watt's Avatar
OK I looked at the Car Today
The Box under the passenger side panel is as follows:
37820-P2T-A11
z4 1170-107918
Engine
B16A2
4308589
The computer box has a bunch of wire coming out of it as a few seam half-*** patched together -
So with this engine in this car are there any wires that have to me moved or change here
it appears something was done. Is there a drawing that shows what colors are what?
Please Advise
I greatly appreciate everyone’s input
when Ifigure out how to post a picture of the car I will
Old Jan 15, 2007 | 09:40 PM
mxs's Avatar
mxs
how to post pictures: https://www.hondacivicforum.com/m_318206/tm.htm
Old Jan 15, 2007 | 09:43 PM
mxs's Avatar
mxs
ORIGINAL: Watt
37820-P2T-A11
z4 1170-107918
Engine
B16A2
4308589
well that's the right ECU for that engine. Assuming the car was really an EX then there shouldn't have been any wire splicing involved, it should just be plug-and-play with the stock harness and everything. If you have pics, though, I'll look at them.
where do you live?
Old Jan 16, 2007 | 11:15 AM
SovXietday's Avatar
Hey Watt, have you read the engine code on the engine? It's on the left hand side of the block, it may be hard to make out but it's right to the left of the exhaust manifold. It should say B16A3 or B16A2. Just want to make sure it says that.
Old Jan 16, 2007 | 02:37 PM
pimpciv98's Avatar
ORIGINAL: Watt
You can download an owners manual from hondahookup.com for that car. Just look at the Civic Si ECU section not the EX section for the wiring even though I guess they should be relatively the same.
I would do a reset on the ECU and see if that changes anything. To do that just disconnect the negative battery terminal and leave it off for 5 mintues (more to be safe) and reconnect it. See if that changes anything.
Have you always had this problem since purchase, or is it a new problem? If it is a new problem I would think that the previous owners install was OK, but if it has been a constant problem, then he did something wrong, i.e something with the ecu.
And this is for the others involved with this problem. Would he be getting any CEL's with an improper connection or anything else out of sync or is that not necessarily the case?
p.s you should be extremely careful when buying a modded car from someone. Unless you have automotive knowledge and can check everything yourself, you are relying totally on the person you built the car which is always a risk.
Old Jan 16, 2007 | 02:51 PM
mxs's Avatar
mxs
ORIGINAL: SovXietday
yeah he already checked, it's a B16A2
fakeblonde
Apr 11, 2006 09:46 PM
Remmy
Dec 16, 2005 12:04 PM
amg6975
Oct 12, 2005 09:17 AM
