dome light question
Old Mar 10, 2008 | 06:43 PM
tano001's Avatar
Default dome light question
i blew my interior light fuse the other and replaced it but now the door option doesn't seem to work. Its either off on and on it doesnt seem to turn off when doors are closed. any suggestions what it might be ?
Old Mar 13, 2008 | 11:56 AM
Default RE: dome light question
Remove each door switch and check them for an electrical short.
Old Mar 14, 2008 | 04:33 PM
tano001's Avatar
I was able to remove all the door plugs or sensors or whatever they called. my question is do i check the plug itself for elctricity or the line its pluged into. and also how do i do that with a basic fuse tester that light ups if it works?
Old Mar 14, 2008 | 06:11 PM
Test each disconnected switch with a continuity tester. In the "door-closed" switch position there should be no continuity between the two terminals whereas in the "door-open" switch position there should be.
dmalee
Jul 10, 2011 05:41 PM
addiction2bass
Feb 25, 2008 01:24 PM
andonato
Jan 11, 2006 12:07 PM
redgst
Apr 3, 2005 01:09 PM
