ecu question
Old Aug 17, 2006 | 03:27 PM
red2000Si's Avatar
Default ecu question
I have a 2000 civic si and I am going turbo in a few weeks as soon as I get all the parts together. I am planning on chipping an obd1 p28 with a conversion harness. My question is whether i should go with a p28 from a 92-95 civic vtec or with p28 from a del sel si which has pretty much the same b16 engine as my car? Or are the two p28's the same ecu? help me out.
Old Aug 19, 2006 | 07:14 PM
MY99SI's Avatar
Default RE: ecu question
use the p28 out of the civic not the SOL. i wouldnt chip it i'de run with hondata s300. you can use a b16 ecu with a vafc2 and make 300hp on a set of 450CC injectors.
Old Sep 11, 2006 | 08:57 PM
blackcivicsi's Avatar
i would go with a p30
Old Sep 11, 2006 | 09:43 PM
HARI.'s Avatar
forget the p28 and p30 ecu and go w/ a p06 and have it chipped and convert it to p28. way cheaper. p30 ecu's and p28's are expensive
Old Sep 11, 2006 | 10:00 PM
finalimpact's Avatar
ORIGINAL: MY99SI
hondata is a chip(system) you install in the factory ecu.............http://www.hondata.com/s300socketing.html
Old Sep 11, 2006 | 10:12 PM
p30 is by far the best obd1 ecu
Old Sep 11, 2006 | 10:32 PM
Pete's Avatar
OBDI is the best for tuning. Get a P28, just make sure shes a virgin, sometimes they lie!!!!!
Old Sep 12, 2006 | 06:35 AM
Marty's Avatar
Actually the P28's in the del sol dohc's are obd2 ecu's. Yep they made a limited number of obd2 P28's
Old Sep 13, 2006 | 12:41 AM
red2000Si's Avatar
well I have looked around town for somewhere to tune once I get a p28 and the cheapest I can find is a place that tunes for $150 an hour and only uses hondata. I was wanting to use chrome because supposedly its free and I dont want to pay $400 for a hondata s200 with boost. What would be another option for fuel management if I didnt go with the p28? vafc2, emanage, etc? Keep in mind I am only looking to make about 210whp. If there really arent any other systems that are safe and wont give me problems than I will shell out the extra cash and make the p28 work somehow. Thanx in advance!
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
