ECU's and Turbo's
Old Oct 21, 2009 | 10:49 AM
  #21
well then like i said it can only be the ecu or another bad dizzy,or plug wires, ill try and do some more research on this to help you, here are some threads about the random misfire and their solutions,
what do all spark plugs look like?
http://www.honda-tech.com/showthread.php?t=2650098
http://www.honda-tech.com/showthread.php?t=2607743
Old Oct 21, 2009 | 11:18 AM
  #22
notnormal's Avatar
Thanks for the post. I read the links u provided. I'll check the fuel pressure and test the pressure regulator. I'll have to go to a bigger town to get an adapter for my pressure tester all I have is for a sharader valve. (American cars)
Old Oct 21, 2009 | 11:21 AM
  #23
it maybe a bad or clogged injector ive read on some threads,
Old Oct 21, 2009 | 11:29 AM
  #24
notnormal's Avatar
I'll check that also, but it still seems to be ignition related, as seen by my timing light. I'll post my results. Thanks
Old Oct 21, 2009 | 11:33 AM
  #25
yea i know that you seen it through the timing light, the only thing i can think of is another bad dizzy, or we can try to overlook the timing light and try other things.
Old Oct 21, 2009 | 11:56 AM
  #26
notnormal's Avatar
Yea. I'll look around at some of the other things. But I feel as if I might be overlooking the obvious if I don't explore all the ignition first. Which it looks as if I have, other than the ECU and I'm not sure how much of a miss that would cause. I also "rebuilt" took apart my OLD dizzy, cleaned all the sensors, refiled 1 of the sensors pickup and reassembled all of it. That seemed to have helped some but I still had the misfire. I'm still plugging away at it. I can't wait till I find it. Just to see what it ends up being! Thanks for all your time and efforts!!!
Old Oct 21, 2009 | 05:50 PM
  #27
notnormal's Avatar
I couldn't find a tester for the fuel system test tonight. So in the morning I'll get a new tester and check the fuel system from the fuel pump to the injectors and post the results for all. I pulled the dizzy that I bought off ebay, off the car tonight and reinstalled the one I cleaned. I'm not sure there was much of a change in the engine between either one. So that would mean if it is the dizzy both are bad. If it's not the dizzy both should be good. I'm looking for a PM6 out of a manual now. Some on ebay, haven't found any left on craigslist yet.
Old Oct 26, 2009 | 09:04 AM
  #28
notnormal's Avatar
OK, after not being able to find an adapter for my tester I built one from a 6mm bolt a piece of fuel line and a brass tubing fitting. I have ran all the following checks on the fuel system, fuel flow, regulator and fuel pressure. All checks OK except for the system pressure reading 3-5lbs low. Which I don't think will cause my misfire prob. I have an ECU on the way we'll see what that does and go from there. ??? What do the pros think? Thanks
Old Oct 26, 2009 | 01:40 PM
  #29
pros??? orly lol... like i said at the meet,(and i wish you took pics lol) i posted pics of your 300z in the who's going thread in the lounge,
its gotta be either the ecu or the dizzy.
heres a link of the pics,
https://www.hondacivicforum.com/foru...t=79075&page=2
Old Oct 26, 2009 | 06:35 PM
  #30
notnormal's Avatar
I'm betting on the ECU. The chance of having two dizzies with them same prb. is probly slim to none. I'll let everyone know as soon as it gets here and I get it installed. Thanks for taking the pics of the 300Z and posting them for us. BTW it's still for sale.
