Engine light on, reset ecu computer?
Old Sep 21, 2006 | 12:25 AM
88civic's Avatar
Default Engine light on, reset ecu computer?
I have an 88 civic and the engine light came on.... now the car wont rev past 4 grand. is that because the car's computer put it in a "safe mode"? and how do i reset the computer?
Old Sep 21, 2006 | 12:40 AM
HARI.'s Avatar
Default RE: Engine light on, reset ecu computer?
there's something wrong w/ your car that's why it went on a limp mode. check the code to find out the problem
HOW TO READ CODES
Old Sep 21, 2006 | 05:44 AM
mentaldis0rder's Avatar
+1 for Advance Auto to pull the code..
Agent of Darkness- Head down to your local AutoZone (most parts stores should also do it) and tell them you have a check engine light. They will pull the code for free.
Old Sep 21, 2006 | 05:06 PM
AgentofDarkness's Avatar
An 88 civic might be too old for AAP or AutoZone to pull the codes. I think that they only have OBDII scanners since OBDI scanners are really expensive. ITs prolly best to pull the codes by jumping the connector. Post the codes and ill look if i can look up the descriptions.
mrtimepa
Jun 20, 2013 08:33 AM
chadtheman05
Oct 21, 2011 08:03 AM
Crcbonjour
Oct 12, 2011 05:14 PM
addiction2bass
Sep 26, 2009 10:10 PM
Auto98EX
Sep 25, 2005 01:41 PM
