Extremely low idle with chipped p28
Old Jun 20, 2011 | 05:55 PM
1armed1's Avatar
Default Extremely low idle with chipped p28
I have a 98 coupe with a H22A swapped in, currently running a p13.
I got a p28 and chipped it.
The chip is base mapped with the stock base map for the motor.
The problem I am having is the idle,
It idles 100-200rpm
If I give it gas it responds very well but will stall when I let off due to the low idle.
I have tried adjusting the idle adjustment and timing with no luck.
Any ideas?
Thanks
Dayton
Old Jun 21, 2011 | 08:10 AM
If you reinstall the P13, does the problem go away?
Old Jun 21, 2011 | 02:25 PM
1armed1's Avatar
Yes, reinstall the P13 and it idles like a champ.
Old Jun 22, 2011 | 08:36 AM
Why do you want to run the chipped p28? Who chipped the p28? Is that chip tunable? If so, what program?
Old Jun 22, 2011 | 02:19 PM
1armed1's Avatar
No egr on the chipped P28,
I chipped it,
Chip is re-burnable, program unknow
Friend of a guy at work made the chip for me, took 3 weeks to get it.
Guy is impossible to get ahold of.
Old Jun 30, 2011 | 01:50 AM
1armed1's Avatar
Idle on the P28 chip is set at 800, so it makes no sense that it idles fine with the P13 but only around 100 rpm's with the P28.
Old Jul 1, 2011 | 06:19 AM
Not sure what to tell you other than contact the tuner again. Maybe something wasn't done correctly when being chipped? Who knows.
Old May 25, 2013 | 10:54 AM
boostedD16's Avatar
im having the same problem with my Y8. i used crome and a stock basemap. it will idle fine for a little bit and then it drops.
Old Sep 6, 2013 | 11:04 AM
zerojett's Avatar
I've had good luck with basemaps from Phearable.net
They're only like $40 shipped.
BoostedD16, initial idle will be higher if you have a FITV, then it will drop. Be sure to jump the service connector.
boreddude564
Jan 26, 2011 07:12 PM
nik005
Oct 18, 2008 10:19 AM
Forty04
13
Aug 30, 2007 06:50 AM
traitorzxiong
14
Aug 15, 2007 07:30 AM
dfdon
13
Feb 16, 2007 09:46 PM
