fmu to ecu
Old Jan 21, 2007 | 02:40 PM
bmxedup's Avatar
Default fmu to ecu
I recently had turbo put in but i had the shop put the FMU in to hold me over until i could afford an ecu... so can you guys tell me all exactly what the correct ecu would do for me rather than the fmu. thanks
Old Jan 21, 2007 | 04:48 PM
riceburner700's Avatar
Default RE: fmu to ecu
the fmu raises fuel pressure as it sees boost. since your stock injectors are 100% duty cycle its like sqeezing there nuts which is bad. the ecu will go in along with bigger injectors and will be programed to your motor/setup on the dyno. the fmu is just a cheap device that ruins injectors and most of the time motors. get an ecu as fast as you can so your motor will last
Old Jan 21, 2007 | 04:53 PM
Kedawei's Avatar
What motor?
Skrapdoggydog
Aug 15, 2006 04:21 PM
mac3a
May 5, 2006 08:44 PM
Chimera02EX
May 2, 2006 04:03 PM
fast93civic
12
Apr 29, 2006 12:30 AM
97exhonda
Nov 16, 2005 08:23 PM
