Fuel Pressure Regulator Questions
Old Sep 23, 2007 | 05:19 PM
TIcivic00's Avatar
Default Fuel Pressure Regulator Questions
O.k. I have a 2000 Civic Ex D16Y8 and just put a aftermarket adjustable fuel pressure regulator on it and was wondering what psi should I set it at and what is the stock psi on the fpr. Any info and suggestions would be great. Thanks
Old Sep 24, 2007 | 05:00 AM
TIcivic00's Avatar
Default RE: Fuel Pressure Regulator Questions
No one knows this answer?
Old Sep 24, 2007 | 05:30 AM
You really shouldn't be messing with the FPR if you don't even know what stock fuel pressure is.
Do you have any other mods that would even justify the tampering of fuel pressure? My motor was turbocharged putting down almost 200hp to the wheels, and even then I didn't need to mess with it.
If you're looking for advice, put the stocker back on
oh, and for future reference..
Helms says
3. Start the engine*. Measure the fuel pressure with
the engine idling and the vacuum hose of the fuel
pressure regulator disconnected from the fuel pressure
regulator and pinched.
Pressure should be:
270 - 320 kPa (2.8 - 3.3 kgf/cm2, 40 - 47 psi) 4. Reconnect vacuum hose to the fuel pressure regulator.
Pressure should be:
220 - 250 kPa (2.2 - 2.5 kgf/cm2, 31 - 36 psi)
Old Sep 24, 2007 | 11:45 AM
Big T's Avatar
Yeah I would leave it stock. I have a FPR as well, I thought that after getting the big 3, I would need to up my fuel pressure alittle. Im sure you dont want to actually return it, so do what I did. Just increase it by like 2or3 psi. If you have an intake, header, and exhuast then it might net you like 1 hp. If your stock I dont think it will do anything. Also, what brand is it? If it is a very inexpensive brand it could very well mess up your car.
Old Sep 24, 2007 | 12:56 PM
TIcivic00's Avatar
it b&m and I have i/h/e but also skunk2 im and 68mm tb. So the stock fuel pressure is 40-47 or 31-36 I'm not to sure what forty posted.
Old Sep 24, 2007 | 02:36 PM
ORIGINAL: Forty04
Helms says
fuel
Pressure should be:
Pressure should be:
do you have a fuel pressure gauge?
Old Sep 24, 2007 | 05:21 PM
SovXietday's Avatar
Should have just left it stock. There is absolutely no need to change that.
TheBlackCivic
Jul 16, 2006 11:45 AM
ficodecko
Jun 16, 2006 06:45 PM
redrider04
Feb 19, 2006 11:27 AM
FastFwd
Aug 3, 2005 11:14 PM
