Gauge swap ?
Old Sep 18, 2005 | 10:39 PM
93cxcivichb's Avatar
Default Gauge swap ?
Hey mighta posted this in the wrong forum b4 so lets c...I have a 93 civic hb cx....duh.....anyway will the 92-95 si gauge cluster directly plug in and fuction with my car or does there need to be special wires run? how does it work???
Old Sep 18, 2005 | 11:34 PM
Dogmeat's Avatar
Default RE: Gauge swap ?
It will plug right in, no extra wires needed. You could also get one from an EX if you are just looking for the tach. (Make sure you get Auto cluster for an automatic and manual for a manual)
Old Sep 19, 2005 | 07:05 AM
Also what about the odometer reading is there anything i can do about the mileage reading or is it whatever mileage is on the car that the gauge is from?
Old Sep 19, 2005 | 08:39 AM
Dogmeat's Avatar
On the back of the donor cluster you will see three phillips (cross) screws. Remove them. The odo. will drop out. Carefully do the same to your original cluster odo. Reverse the process and do not touch any needles no matter how tempting it is. At least not on the cluster you plan to use. Will work fine.
As a side note make sure all the bulbs work before you put the cluster back in. Multi tester pull all and check.
Old Sep 19, 2005 | 01:51 PM
Remmy's Avatar
Yea, youll be fine with a swap. Like Dogmeat, i also suggest you score and EX cluster. It would be kinda tacky to have an Si cluster in there if you dont have the b series to back it up : / .
Old Sep 21, 2005 | 09:12 PM
97civicturbo's Avatar
Does the si hatchback have dohc????
Old Sep 23, 2005 | 04:39 PM
EK4_B18C5's Avatar
no, the EG SI's don't come DOHC. they are all SOHCs and if you put in an SI cluster, all you need is honda's famous VTEC......and like DOGMEAT says....it will plug right in, no extra wires needed.
Old Sep 26, 2005 | 03:53 AM
exactly, was wondering why rem put that comment about the DOHC.
Old Sep 30, 2005 | 07:51 AM
asmayo's Avatar
What about a 98 EX swapping into a 98 DX? No extra wires or anything?
Old Sep 30, 2005 | 09:27 AM
Remmy's Avatar
nope, plug and play
Faramire
Sep 7, 2009 02:27 PM
siwel177
12
Jul 17, 2009 06:47 AM
TurboToyzz
Feb 16, 2007 12:46 AM
xjbmx
Aug 19, 2005 06:32 PM
millertime17
Jun 26, 2005 09:38 PM
