Idle Air Control Valve
Old Dec 25, 2007 | 01:41 PM
10shelw's Avatar
Default Idle Air Control Valve
Do you need a idle air control vavle for a 00 civic EX? I bought a new intake manifold off of ebay and there is no spot for the idle air control valve.
Old Dec 25, 2007 | 06:11 PM
Obligatory's Avatar
Default RE: Idle Air Control Valve
I think you'll throw a CEL (code 13: IACV sensor) and your idle will fluctuate up and down
Old Dec 25, 2007 | 06:20 PM
ef4life's Avatar
yes you need it. its helps stabilize the idle at a normal level. so when your a/c kicks on it does't stall your engine, or when your parking and the power steering is running at high pressure and putting excessive drag on the motor at idle, it will stay at the same rpm.
its also used as a signal to the ecu to determine injector pulse width along with many other sensors in your car.
Old Dec 25, 2007 | 06:38 PM
Hola's Avatar
guys now in my 00 civic the rpm goes mad, i cleaned the iac valve but still at fault
KILLER
Jun 11, 2006 09:56 PM
jim9418
Apr 25, 2006 11:22 AM
jim9418
Apr 21, 2006 06:01 PM
Hawk284
Sep 8, 2005 12:20 PM
jlh911
Jun 30, 2005 09:52 PM
