Idle sensor
Old Dec 8, 2007 | 07:07 PM
sdaly00014's Avatar
Default Idle sensor
ok i have an idle sensor that is fed up, and i am wounderin what is a quick and easy fix.
Old Dec 8, 2007 | 07:16 PM
Default RE: Idle sensor
Many on the forum have mentioned that cleaning the IACV with carburetor cleaner can solve some idle problems.
See procedure described by Forty04 here:
https://www.hondacivicforum.com/m_523561/tm.htm
Old Dec 10, 2007 | 07:55 PM
its ur throttle position sensor and u have 2 ways of changing it
1) take the 4 bolts and unclip sensor and vacum lines and swap the whole piece
2)take a dremel or a hacksaw and make a dash into the 2 rounded bolts holding the senor on and then use a flat head to remove screws and just change sensor.
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
