MOTOR OIL
Old Jun 25, 2006 | 09:30 PM
klepto's Avatar
Default MOTOR OIL
I HAVE A 01 CIVIC COUPE AND IM NOT SURE WHICH KIND OF MOTOR OIL I SHOULD PUT IN IT, WOULD SOMEONE TELL ME WHICH KIND IS BEST...THANK YOU
Old Jun 25, 2006 | 09:46 PM
Belmont's Avatar
Default RE: MOTOR OIL
Theres not really a "best" motor oil. Royal purple is pretty much top of the line, but expensive. Anything like mobil 1, castrol, quaker state... Pretty much any oil that an auto store sells is fine. Also honda recomends a 5w20 motor oil. And dont forget to take off the caps lock.
Old Jun 25, 2006 | 10:36 PM
riceburner700's Avatar
perferably synthetic oil would be better for your civic and give you a few more mpg on every tank..but you dont "HAVE" to use sythetic, plain motor oil will work just fine
Old Jun 25, 2006 | 10:41 PM
klepto's Avatar
DOES IT DEPEND ON THE MILEAGE, I HAVE ABOUT 96,000 ON IT
Old Jun 25, 2006 | 10:47 PM
Belmont's Avatar
Nope, but eventually you will want to switch over to high mileage engine oil.
Old Jun 27, 2006 | 07:00 PM
pWnEdU's Avatar
The "high mileage" oils are a gimmick IMO. When the rings start to wear, just bump up the viscosity a bit.
And WTF is with all these people and caps lock?
Old Jun 27, 2006 | 11:57 PM
couldnt tell ya^^^
Old Nov 20, 2006 | 10:37 AM
the_turtle's Avatar
what about valvoline max life...my grandpa said it made his truck burn/leak oil bad, and i dont want to use it if its crappy stuff...
Old Nov 20, 2006 | 10:52 AM
Fiirkan's Avatar
for some reason when i see someone typing in all caps, i can hear someone yelling the words in my head and it hurts...
Old Nov 20, 2006 | 11:13 AM
the_turtle's Avatar
no doubt, but any reply to above???
