NEED HELP ASAP on ECU AND BODY WORK
Old Oct 23, 2008 | 06:15 AM
ricaninacus's Avatar
Default NEED HELP ASAP on ECU AND BODY WORK
i have a 95 coupe wit a SOHC V-Tec wat is a reccommended ecu to put on a SOHC so it can run a little harder, i have MSD, DC headers,intake and exhaust, im just looking for a push from an ECU and how would i change the front clip to that of a 3rd gen acura?? that shyt looks sick
Old Oct 23, 2008 | 11:53 AM
the ECU you have is the only one you should use
If you can solder, and you want to squeeze a couple ponies out of it, you could get a chipping kit from Phearable.net for $35. Just whatever you do, DON'T GET AN EBAY CHIP!
On the order form, tell them your modifications, and put 5000 for VTEC engagement (this is pretty much stock, which is a good setting for it), and leave the redline alone because you don't need to go any higher and you risk serious engine damage by doing so without a built engine.
With the basemap they give you you'll have a little more aggressive fuel map and you'll need to run 91 octane or higher gas.
90Civtegra should be able to help you on the acura front end details
x1mpr0x
Sep 4, 2009 07:44 PM
ricaninacus
Oct 23, 2008 10:31 AM
asianboy
West
Aug 18, 2008 02:26 PM
soldout712
Oct 30, 2006 04:03 PM
lilol89crx
Jul 29, 2004 06:56 PM
