is this ok?
Old Sep 28, 2007 | 11:42 AM
blackmetal619's Avatar
Default is this ok?
so i am considering buying a chipped ECU from phearable for $175.
So its just plug and play?
Is there anything wrong with running this ECU with just I/H/E?
Im gonna be putting on a throttle body and intake manifold if that makes a difference?
anything else I need to know?
Ive been reading up alot about them, and am just curious about them
Old Sep 28, 2007 | 04:56 PM
burnindesirez02's Avatar
Default RE: is this ok?
Yes it should be just plug and play... But make sure there are no modifications done to the chip like a 1.8L fuel map if you have a 1.6L or you will be running very rich and fail emissions by alot if you have em.
Old Sep 28, 2007 | 08:25 PM
danomatic93's Avatar
June 2010 ROTM
phearable is a great place to get a safely chipped ECU. I and another HCF member have the chips from phearable. I have yet to solder mine in but, I'm waiting for some free time to do it.
I chose to just buy the chip and install it myself. But you can also get the chipped ECU and keep or sell yours.
Old Sep 28, 2007 | 08:42 PM
cool thanks for the info guys.
Yea i want to buy a already chipped one, so i can swap my stock one back for emissions.
how much did you notice the gains?
Also, I dont need to solder anything right? Its basically just a bolt on, I just wanna make sure before spending $255 on it, cause that could be suspension money haha
Old Sep 28, 2007 | 08:54 PM
June 2010 ROTM
Right, you can buy the pre-chipped ECU for 175 or whatever, or buy just the chip and and solder it to your ECU for 30.
Old Sep 28, 2007 | 09:07 PM
ok cool. i like the plug and play idea.
is it worth chipping with I/H/E and skunk2 intake manifold?
Old Sep 28, 2007 | 09:12 PM
June 2010 ROTM
yeah, it remaps your fuel and air intake to be more efficient/powerful on the gas (which you have to run mid-grade or higher). Worth it?, sure.
Old Sep 28, 2007 | 09:15 PM
if i add more mods later, do i need to do any changes to the ECU?
thanks for helping
Old Sep 29, 2007 | 06:02 AM
June 2010 ROTM
Well, you definitely can and probably should. Since you plan on getting the chip from Phearable, you can update the chip as you see fit. Once the ECU is chipped, the main "logic" chip can be removed to switch with a different "logic" chip. It's only 15 bucks to update.
