Performance Chip ????
the risistor that you put in the temp sensor will screw up the signal that it sends back to the pcm and put the computer into open loop mode,it tells the computer that the vehicle is running colder then norm. in that mode, you have pre-set fuel levels wich is usually to much fuel. in the end it takes away the reason to have obd2 and its allmost like goin back to old school. they want the fuel to air ratio to be 14.7 to 1 because that its when all the fuel is burned and will not polute to much and the o2 might not take any signal because the computer thinks its not warm enough... so i suggest just useing that resistor at the track. mabie try it out that way.
