Please Help!! Injector, valve, or tune?
Hey guys, ok, so on sunday as i pulled out of kroger, my engine and exhaust started belching a s**t load of smoke. I began dissassembly yesterday and found the culprit. Youll hear it again and again on here, my XS Power turbo from ssautochrome took a dump and spewed oil all over my engine bay, exhaust manifold, downpipe. So, i cleaned up the block and stuff, and wanted to just crank it over to see if anything was going on with compression. I left the wires off and began, then my assistant let me in on the weirdest thing. During the cranking over, fuel began to run out of the #2 cylinder exhaust port????? My car was not previously tuned and is notorious for running freaking rich, BUT what would explain the fuel coming out of just the one port??!! Now, i have heard 4 different things: Injector is stuck open and just pouring fuel, valve seat, doing it just because its not tuned, or the injector is clogged or angled in the manifold. Now, i have ordered a new turbo, but this is still a problem that needs to be addressed before i put everything back together. Please let me know what you think.
Like Marty said, it's pretty hard to diagnose without being there to actually see and hear what's all going on. But, I will tell you that when I had my injectors wired incorrectly, I too was spewing fuel out of the exhaust port. How are your injectors wired? Is everything soldered? If not, go through all your injector wiring and find the loose connection. It'd be a good idea at this point to solder everything.
Cool, so, back to problem at hand. I understand that being here thing, but just off the top of your heads, what does it sound like. Just tell me its not a valve problem, i dont want to even want to attempt that.
redlines4us
Apr 25, 2021 06:20 PM
