Power locks don't work....please help!!!!!!!!!!
How are you testing for power? What terminal of the connector are you testing for power?
Check whether you have power at fuse 51 when the ignition key is turned to On.
There is no solid green or white wire attached to the connector (see table in post #8)?
Also, how are you checking for battery voltage? You need to touch the + probe of the multimeter to the said wire terminal and the - probe to a metallic part of the door frame.
ORIGINAL: jdizel
The power wire was green and white, I think. It has no power. I know we tested the 12 volt wire and it had no power.
Okay, now check whether you have power at fuse 51. This is done by removing fuse 51 and then touching the + probe of your multimeter to the battery-side terminal of fuse 51 and the - probe to a metallic part of the frame under the dash. If you don't detect battery voltage, then similarly check the other terminal of fuse 51. If there's no voltage at either terminal, then the under-hood fuse box is likely bad. If you do detect battery voltage, then either fuse 51 is bad or there is an open in the WHT/GRN wire running between fuse 51 and the power lock control unit. The latter can be verified by performing a continuity test (Ohms) on the WHT/GRN wire.
I recommend that you first try to locate the open in the WHT/GRN wire. This might be done by performing continuity tests from fuse 51 to various points along the wire, moving closer and closer to the power lock control module. This procedure would require removing small sections of wire insulation to expose bare wire to test.
