Reseting ECU
Old May 10, 2005 | 11:37 PM
D16z6's Avatar
Default Reseting ECU
Is it true that once you install CAI, header, cat back and all those other mod you should reset your ecu????
Do you reset the ecu by unhooking the battery???
Old May 10, 2005 | 11:42 PM
Pete's Avatar
Default RE: Reseting ECU
ya just unhook the Negitive terminal and leave for 15 mins....i dont think after CAI u need to thou.....the comp automaticly does it.
Old May 10, 2005 | 11:50 PM
D16z6's Avatar
ok thanks i was just making sure.
Old May 11, 2005 | 10:00 AM
polo708's Avatar
anytime that you mess with something affecting the air/fuel mixture. So for an intake, exhaust, header, etc...
Unhook both the positive and negative from the battery. Then (away from the battery) touch the 2 leads together, then re-connect. Start the car and let it idle for about 10 minutes.
Old May 11, 2005 | 10:23 AM
LEVIII's Avatar
It is important to let it idle to reset all the maps to the new mods you installed, most people just want to jusmp in a nd take off.
Old May 11, 2005 | 10:26 AM
polo708's Avatar
exactly, it has to adjust to the idle a/f ratio... when you start it up dont press the gas at all, just turn the key and walk away
00civichonda
Jun 13, 2012 04:42 AM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
