Rough Idle...
Old Oct 19, 2006 | 06:13 PM
greybullit's Avatar
Default Rough Idle...
I got a 90 hatch with a 1.6L Vtech. At idle, after its warmed up, it has a rough idle varying rpm's from 500 to 900 or so. It has an intake, exhuast(no header) a DC Sports ECU. I'm not that experienced with fuel managment, haven't gotten that far in school yet, anyway, any help would be appreciated, thanks.
Old Oct 19, 2006 | 07:22 PM
civtec00's Avatar
Default RE: Rough Idle...
it might be the throttle body gasket
Old Oct 19, 2006 | 07:26 PM
Pete's Avatar
check for a vac leak.......bleed the coolant system, air in there can cause a rough idle. Sounds like a vac leak, see if all the hoses on the intake manifold are hooked up correctly
Old Oct 20, 2006 | 11:43 PM
AgentofDarkness's Avatar
Get a bottle of carb cleaner and spray the engien wherever you think there is a vac leak. If there is a vac leak then the carb cleaner will get sucked in the engine and you should be able to see the carb cleaner getting sucked in.
Old Oct 21, 2006 | 12:59 PM
SovXietday's Avatar
IACV, take it out, clean it out, see if that fixes your problem. I don't think it's a vac leak.
Old Oct 21, 2006 | 01:05 PM
intense_gravity's Avatar
or you can check your map sensor.... did you not plug it all the way in... map sensor is located on top of the throttle body
Old Oct 26, 2006 | 10:36 PM
greybullit's Avatar
ORIGINAL: SovXietday
Whats IACV?
Juice75
Dec 15, 2012 05:16 AM
Stumasters
Jan 20, 2008 12:58 PM
Howieb
Nov 21, 2005 09:28 AM
Ed
Feb 27, 2005 07:29 PM
kjreinha
Feb 4, 2005 01:58 PM
