RPM's running real low...idol at 200ish
Old Nov 15, 2005 | 09:26 AM
b18b1civic94's Avatar
Default RE: RPM's running real low...idol at 200ish
u may want to check ur fast idle thermo valve. it is located under the tb and it has a coolant line running to it. it has 3 10mm bolts holding it in, take them out. disconnect the coolant line. YES UR ARE GOING TO SPILL A LITTLE BIT OF COOLANT. there are to 8mm bolts holding a plate on, it is the opposite side of the where the coolant line goes. take the two bolts off, remove the plate. and u should see a white disk. take a flathead and turn it clockwise. which will tighten it. and put it all back together. it should fix the ur idle. i had the same problem with my 94. it was idling right around 400-500. the it would stall. till the motor became operating temp.
Old Nov 15, 2005 | 02:22 PM
civicexracer's Avatar
ya i think im going to have to do that this weekend sometime....i got new spark plugs, cap, rotor, pcv valve, and an aem sri and the rpms are still low so i think turning those bolts or w/e is prolly my best bet.
thanks for all the help guys!
i really appreciate it!
Old Nov 15, 2005 | 04:35 PM
neon3kgt's Avatar
what about idle air control valve?
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
scottsilke
Mar 25, 2007 06:58 PM
Street Sniper
Mar 25, 2007 06:08 PM
civicexracer
Oct 4, 2005 07:53 PM
