stuck..AAARRRGGGHHH!
o.k. first lets go back.. installed the 1.6 mpfi.. rewired from dpfi.. that motor had severe problems... in goes the b16.. i had problems there with ,, im not sure, but fuel would not stop.. no spark... headache's.. so i took out the wiring harness from the engine, (the converted harness) and im rewiring it with the vtec harness.. and i have the pr3 ecu.. but every diagram and pinout i find just are not adding up!! i dont have 26 pins in my a plug, and none of the wires are where they should be.... somebody's gotta know what im talking about... i have the itch, i want to drive, im tired of being on my back and dirty, somebody point the way so i can get my a__ in the drivers seat, where it belongs... thanks
umm... the whole thing, a colorblind guy should not be doing this... yet, here i am. lets start with block a. diagrams i find say there are 26 pins.... my plug only has 16... block A is the only one thats not black, correct? is this an obd0, obd1 issue? i come up with p30 when checking site's, but i find no options....
i dont think that is what im doing? engine swap... a little while ago i swaped from d15 to d16, had to cnvert from dpfi to mpfi... now i have the b16 in the car, with an ecu to go with it and also the engine component harness... i received the harness already off the motor.. and trying to follow wiring diagrams is not exactly my specialty..
you missed the most challenging aspect, wires are color coded... i am colorblind..very colorblind!!!
heresa couple pics of what im up against.............. too you it may seem cut and dry, but to me, its a bunch of wires that all look alike
[IMG]local://upfiles/1438/C9FFC404C47246EC8683EA7342C0AD3C.jpg[/IMG]
[IMG]local://upfiles/1438/7A2BA23B25EB4514B0A4B15233C8DE76.jpg[/IMG]
[IMG]local://upfiles/1438/EB7E593F46C648E8B28EC2176CDDD5C4.jpg[/IMG]
ill try to find a diagram that goes by pin location only(wish me luck) now that i know your color blind this will be a very hard task. and block C is actually the non black block. in order of ABC your blocks are black black white.
