stuck..AAARRRGGGHHH!
Old Jan 25, 2006 | 12:53 PM
jwsimons's Avatar
Default RE: stuck..AAARRRGGGHHH!
that could explain alot!!!!!!!!!!!!!!!! d'oh!
id appreciate the help. lacking confidence in myself for this particular task... (good luck)
i can get somebody to help with the colors.. i just need to be certain everything is in correct spot(because of previous conversion to ecu harness)
ORIGINAL: finalimpact
ill try to find a diagram that goes by pin location only(wish me luck) now that i know your color blind this will be a very hard task. and block C is actually the non black block. in order of ABC your blocks are black black white.
Old Jan 25, 2006 | 04:26 PM
ef4life's Avatar
if you don't want to wire it yourself. i know www.rywire.com will build you a harness if you send them your core harnesses for the plugs. it might be something for you to look into, even though it might be a little on the expensive side
Old Jan 25, 2006 | 05:06 PM
jwsimons's Avatar
im hoping to have this finished, maybe tonight , if i get lucky... ive been looking at this engine for so long now!!! i need to hear it, feel it, take some corner's!!!!!!!! thank you, but that is definately a last resort, and its not wiring that im bad at, its identifying that kicks my buttocks
Old Jan 25, 2006 | 10:47 PM
jwsimons's Avatar
r u positive? i have a diagram from kappa that clearly shows just the opposite
http://thenew.gamesbbs.com/~dmoore/i...u-pin-outs.xls
and just to add to the confusion, some say all the odd are on top and the even on the bottom, while others state that the sequence runs top, lefyt to right, then back to left bottom and continue......... this really f'n blows
farfrumugen1
Nov 14, 2006 01:00 AM
boynblue
Oct 7, 2005 01:02 PM
Ray012874
Aug 17, 2005 11:57 PM
Cappelle
May 18, 2005 09:52 PM
cheffsez
May 11, 2005 07:35 PM
