fuel door stuck shut?
Old Sep 8, 2005 | 07:38 PM
farfrumugen1's Avatar
Default fuel door stuck shut?
my fuel door is stuck shut i popped it open but i was wondering what i could doo to actually fix the issue
Old Sep 8, 2005 | 08:27 PM
Pete's Avatar
Default RE: fuel door stuck shut?
the hinge is going to need a little attention. It may need to be bent a tad.......and im sure some good ol' WD40 wouldnt hurt it either.
Old Sep 8, 2005 | 09:11 PM
kazunori's Avatar
And make sure that when your pulling on your release lever its actually PULLING. You may have a snapped cable or there may be excess slack.
Old Sep 8, 2005 | 09:44 PM
mxs's Avatar
mxs
That happened to me once on my old Civic. Release cable was still working and all, I think I just had to bend the tab on the door a little bit.
How did you get it open??
Old Sep 8, 2005 | 09:53 PM
i was able to get it open by gently pushing my key in the door gap on the tab side and pushing inward and pulling outward. the wierd thing is is when i pull on the handle it doesnt want to move at all. i even tried vice grips and it didnt budge but i did not want to use to much force. just a little history on the car . i just bought it and got it home its a 93 cx it sat for a little while but the guy wasnt for sure how long but at least a few mos.
Old Sep 8, 2005 | 10:10 PM
mxs's Avatar
mxs
hehe... mine was a 93... and I got it open with my swiss army knife.
Sounds like you need to lube the release cable somewhere, but I don't know where.
Old Jul 27, 2006 | 10:26 PM
howard55's Avatar
i pushed down on the fuel opener. nope wont open...i opened the trunk, removed the side carpeting & found the cable end (actuator) & turned it,, sucess it popped open. got gas then had to reinstall it to close the door. Dealer says it costs $160. ouch
Old Nov 14, 2006 | 12:40 AM
teammo's Avatar
This may help out others with this problem . You can purchase a repair kit for the fuel door release cable at this web site Fuel Door Fix
It is easy to install and cheaper that a new cable!
Old Nov 14, 2006 | 01:00 AM
Misha's Avatar
For some reason I got weird feeling that those three noobs are working together for the same advertizing agency. Sorry if I'm wrong.
tyler2004ex
Feb 12, 2017 08:53 AM
alpinegroove
36
Oct 29, 2013 08:07 PM
vXc760
Sep 17, 2012 07:05 PM
bank5
Mar 28, 2011 03:13 PM
95CIVICUS
29
Dec 12, 2005 07:03 AM
