STUCK WINDOW PLEASE HELP
I have a 98 EX civic with a passenger window stuck half way up. It was making a popping noise sometimes when I would press the button to role the window up an down. Now will not do anything. I have the door apart but its dark an I cant figure how to push the window up until I have a new motor for it or whatever is wrong with it. Any info would be much appreciated.
Thanks
Thanks
try popping it in the weather seal if its knocked out, when i was in my accident the passenger window got knocked out so we will have to take the door apart to realign it since its off track in the door
IF YOU HAVE THE DOOR APART, THERE ARE 4 BOLTS THAT HOLD THE GLASS TO THE REGULATOR. YOU PROBABLY BROKE THE CABLE FOR THE REGULATOR SO YOU WILL HAVE TO REMOVE THE REST OF THE CABLE AND PUSH UP THE WINDOW. ONCE YOU DO THAT GET SOME SPRING CLAMPS TO HOLD THE WINDOW UP.
