userfriendly ECU
Old Aug 16, 2006 | 09:39 PM
koots's Avatar
Default userfriendly ECU
what is the most userfriendly programmable standalone ECM on the market? i am severely interested in this
Old Aug 17, 2006 | 06:37 AM
Chimera02EX's Avatar
Default RE: userfriendly ECU
I suggest putting a standalone ECU off until you would have use for one. Even I/H/E TB/IM don't require a standalone, if you were going to do headwork and get a stage 2 cam put in then yeah ok I can see a standalone, but until that time it's not worth the $2k+. You also have OBD2 so that doesn't leave you with many options unless you convert to OBD1. AEM EMS is the best for OBD2. <-- Personal opinion.
Old Aug 17, 2006 | 11:10 AM
koots's Avatar
thinking of goin turbo after all the nice folks in the forums here got me jazzed up about it. i was planning on spending that much on my truck on a lift kit anyway, but the civic crushed that dream and replaced it.
Old Aug 17, 2006 | 03:01 PM
Skrapdoggydog's Avatar
AEM EMS is the best out there and the most expensive. if u are going with a crazy turbo setup and shooting for high boost 20+ then i would get it but if you are just going to run normal boost pressures like 7-12 and have an OBD1 then i would just chip ur ecu and have it tuned with crome, neptune etc. just my $.02.
Old Aug 17, 2006 | 04:14 PM
koots's Avatar
thanks man. i was thinking of running low boost to keep pressures down, cuz i'm not looking for crazy numbers (160-200 would be perfect)
Old Aug 17, 2006 | 05:01 PM
96+ has OBD2 so unless you convert chipping isn't an option.
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
