Wierd CEL. Wont start sometimes
Old Jun 29, 2007 | 02:46 PM
demonboy279's Avatar
Default Wierd CEL. Wont start sometimes
I need some advice. My 92 civic lx auto, that im gettin back on the road is giving me a headache.
Usually she starts up without a problem. Sometimes shes slow to start. But occasionally the CEL doesnt go off like it should and the car wont start she just keeps cranking. Today i found out she doesnt send gas while shes having that problem.
The CEL stays on while its cranking. But when i hook up a jumper wire to check the CEL the light doesnt blink. I got aggravated at that today and unhooked the jumper and just sat there with the key in II position. When all of a sudden i heard a click sound from the fuse area and the CEL went off and the fuel pump kicked on. So i turned the key and she fired right up like nothing ever happened.
What should I be looking at here?
Old Jun 29, 2007 | 06:13 PM
cpl rampage's Avatar
Default RE: Wierd CEL. Wont start sometimes
Check the main relay, they are a common problem on these cars, a lot of the time a solder joint goes bad, and it only works intermitently
Old Jun 30, 2007 | 02:32 PM
im going to do that today can you tell me exactly what im soldering on the main relay? take it apart? or the wiring harness?
Old Jul 1, 2007 | 06:51 AM
i dont know exactly where it could have failed, but the easyest thing would be to swap out a good one and see if that solves your problem, if you cant to that, open it up, and look for any poor solder connections.
cosmond
Dec 14, 2009 04:43 AM
flattire
28
Feb 3, 2009 03:37 PM
russell
Jan 16, 2008 02:58 PM
Inev
Mar 23, 2007 12:26 AM
carlover
Aug 2, 2005 10:07 PM
