Wrong ECU means less power?
Old Sep 28, 2010 | 03:34 PM
d16z6-10's Avatar
Default Wrong ECU means less power?
I swaped out my d15b7 for a d16z6 vtec but the old harness and ECU are still running the new engine, this new engine has 25 more HP than my previous one but I am not noticing the power (hp) difference, could the problem be that I need the correct ECU for the d16z6 vtec engine?
Old Sep 28, 2010 | 09:04 PM
D15B7 ECU doesn't have VTEC functionality... so yes, that is the problem. Also, you have to run the wires for VTEC.
Old Oct 1, 2010 | 04:07 PM
rc2904's Avatar
Not trying to thread jack or anything but couldnt he use like a po6 ecu and just solder in the vtec chipset instead of spending more for a p28?
Old Oct 1, 2010 | 09:44 PM
yes, but it requires skill and a good soldering iron. It's real easy to mess up the ECU while trying.
Info towards the end of this sticky
https://www.hondacivicforum.com/foru...ad.php?t=73241
Old Oct 2, 2010 | 10:27 AM
texasmade's Avatar
the fuel map is a little differant to so its best just to get a the right ecu and yes you will notice a huge differance when you run the p28 cuz i did the same thing on my first swap
DannyHC
Jun 19, 2009 05:45 AM
BrianT
Dec 28, 2006 01:03 PM
ic892003
Nov 29, 2006 06:53 PM
procivic
May 19, 2006 11:41 AM
