ED-EF Swaps 1991 and older Civics, CRXs
B16A OUT OF 93 CIVIC
Old Jul 4, 2006 | 11:25 AM
89si's Avatar
Default B16A OUT OF 93 CIVIC
ive got an 89 si crx and i can get a whole car with a b16a that was wrecked it has a red valve covver with a tranny and it runs i can get if for cheap what would it take to put the b16a in my car what other parts will i need other than the whole car
Old Jul 4, 2006 | 11:06 PM
finalimpact's Avatar
Default RE: B16A OUT OF 93 CIVIC
since its coming out of a 93 you would need the hasport mount kit with the hydro to cable conversion. also if im not mistaken you will have to shorten the shift linkages from the 93 my 2". you wouldnt be able to use the ecu unless you convert to obd1 which i highly recomend.
Old Jul 8, 2006 | 11:21 PM
89si's Avatar
so what exactlly is a half shaft and what is the purpose and is their two different motor mont kits one for a hydro and one for a cable tranny
Old Jul 9, 2006 | 09:41 AM
half shaft is a shaft that helps to keep the axles equal length. it goes into the transmission and bolts to the block. this item helps to keep torque steer at bay. and you will need the hydro kit if your tranny is hydro
Old Jul 9, 2006 | 05:48 PM
89si's Avatar
so will i need to get a obd1 conversion my ecu is fried so what is the recomended ecu to run other than the wiring conversion and the motor mount kit will i have to do anything to my wiring harness and what about half shfts are they needed for this swap and is their any site i can go to to get this info
Old Jul 13, 2006 | 04:44 PM
89si's Avatar
hey all these hits and nobody can tell me what i need i seriouly need help if i had this kinda info i could be done with it and able to drive it
bcivic
Aug 13, 2007 11:56 AM
cadman421
EK Swaps
May 11, 2007 12:47 AM
psikyk
16
May 8, 2007 09:30 AM
xxeddixx
Aug 24, 2006 05:06 PM
LEVIII
Oct 18, 2005 01:31 AM
