EG Swaps 1992-1995 Civics
best motor to swap into a 95 civic ex coupe
Old May 24, 2007 | 07:41 AM
smalz's Avatar
Default best motor to swap into a 95 civic ex coupe
i got a 95 civic ex coupe with a blown d16z6 motor, i wanna put insomething quick but dont no wat
Old May 24, 2007 | 08:11 AM
MY99SI's Avatar
Default RE: best motor to swap into a 95 civic ex coupe
how much money are u lookin to spend? the b series is the simplest,H series is like the Bigg block of honda's, and the K series is rarest and prolly the coolest to do IMO but its expensive.. its all upon how much you want to spend
research is key.
i'de drop a stock replacement in there for now and when you get some money to get a better swap i'de do it
Old May 25, 2007 | 03:48 AM
Kedawei's Avatar
F-series.
Old May 25, 2007 | 04:11 AM
ORIGINAL: Kedawei
F-series.
w00t!!
Old May 25, 2007 | 04:23 AM
FlipHKD720's Avatar
it all depends on budget, you could swap another z6 in there and then boost it, which would give you similar numbers to a stock B. I think that'd be the simplest
Old May 25, 2007 | 08:07 AM
mxs's Avatar
mxs
https://www.hondacivicforum.com/m_10612/tm.htm
read this and decide for yourself
Old Jun 20, 2007 | 06:19 PM
taintedsaint's Avatar
Hey i'm in the same boat bro so im gonna run u through what im thinking about doing. I think it will be the most straight - forward, and affordable way possible. I was just cruising craigslist and found a handful of 94 integras for under 3k. Now you may not want to do this but i want a few things (upgraded brakes, seats, gauges, misc things that i havent thought of yet) but i'm gonna try to get the whole car and just swap EVERYTHING over. Way cheaper than buying everything separately i think. In theory i'll save a butload but who knows how it will pan out. I'll geta 140hp b18ca out of it with (hopefully) everything i need to slap it in my eg and i should be set. I'll have an degc2 haha. Eh, hope that helps. Good luck man
toughtransam36
Sep 28, 2010 05:40 PM
acortez97dx
EK Swaps
Sep 19, 2010 07:47 PM
tlkolrod
ED-EF Swaps
Nov 28, 2006 12:37 AM
deadone000
EG Swaps
Apr 16, 2006 11:11 PM
