D series swap suggestions
k if i posted this in wrong thread i'm sorry but i need quick answers.
story:
I have a 1995 honda civic dx 5 speed trans, i'm sure it has a p06 ecu (stock) obd1. the engine was swapped out with a d15b vtec. it doesnt have the solenoid installed. I went and got emissions and failed misserably. took it to a shop and they said it was running lean... obviously since i failed on my hydrocarbons and the other one (forget name).
what i've done:
i've replaced the entire exhaust. starting at headers all the way to muffler. yes i'm including catalytic.
i've replaced plugs and wires and cap and rotor. not the cheap either.
had the injectors cleaned.
I'm running out of options because i've pretty much covered all the issues that involve hydrocarbons. the car runs beautiful except for the occasional sputter. check engine lite is on. the only thing i can think of next would be either the o2 sensor and/or the ecu. which ecu would be the best to install with this engine. please help.. i've driven myself mad with this ordeal.
thanks to anyone that can help.. it would be much appreciated
story:
what i've done:
this is a zombie thread because it's several YEARS old. But anyways, onto your problem. Go to your local Autozone and have the code pulled for the Check Engine Light. That code will tell you whats wrong, then you can fix it. simple as that.
Autozone doesn't do OBD 1.. they can only provide OBD 2 codes. I already tried that. I'm just not sure if this computer is reading the codes from the other engine or not? I heard that happens. it's not a vtec computer and i have the vtec engine after swap. would that throw codes and cause a lean burn?
Thanks for the help, do you have any suggestions as to which ecu i should put in with the engine? i've read that the p28 would match good. is that a vtec ecu? and if i left the solenoid out, would it still throw codes? thanks again. you've helped me more than anyone i've contacted thus far.
99silverSI
Apr 6, 2008 01:49 PM
topdogmancivic92
Aug 28, 2006 09:12 PM
Need Gone NOW!!!! D1 Tow Hooks, D15B7 swap, DX tranny, GSR Axles, D series linkage, EF B series Link
S240161
Nov 3, 2005 08:35 PM
