EG Swaps 1992-1995 Civics
four door swap
Old Dec 26, 2005 | 08:14 PM
Fiero_Gold's Avatar
Default four door swap
i have a flooded out 93 fourdoor civic, it has the old 1.5L in it (d15 right?) and i wanna put a 1.6L v tec motor in it (b16a right?). will the D series transmission bolt to the B series motor? and i need to know about wiring harnesses and ECU's. tell me everything i need to do this swap. this is what i have in mind
Block (with rods and pistons and crank) all the motor of course.
Intake mani
Complete head
sensors
exaust mani
Fuel Rail
Injectors
distributor
starter
throttle body
alternator
powersteering pump
Water pump
Oil Pump
timing belts and other belts
axles and shift linkage
im on the right track right? plus do many people put v-tec motors in 4doors? lemme know yall im serious about this swap.
Old Dec 27, 2005 | 11:21 PM
AgentofDarkness's Avatar
Default RE: four door swap
If its flooded, get rid of it. The thing about water is that it gets into everything. Your car has a lot of electronics and chances are that there are gonna be alot of shorted boards and such. So you might end up droppin a new motor into it and find that there is a new electrical problem every week. Electrical problems are a bitch to fix.
Old Jan 14, 2006 | 06:18 AM
natecivic92's Avatar
I have the 92 civic dx d15b7 which is sedan which is 4 door.I have spent alot of time looking into motor swaps and the d15b is jdm vtec it will bolt up to trany so will d16z6,d16y8.I will need
a p28 ecu,plug and play wiring to vtec,and motor.A jdm b seris motor will not bolt up from what I have learned you will need tranny,axles,ecu,wiring.I would rather go d16z6 and build for boost
then go jdm.[&:]
GRENDAL
Mar 9, 2007 10:41 PM
ryan69
Jan 9, 2007 10:49 PM
civicman1998
Nov 20, 2006 08:44 PM
Crook_EG8
Jul 23, 2006 01:52 PM
bdub
Jan 21, 2006 05:37 PM
