EG Swaps 1992-1995 Civics
Help! LOL
Old Dec 7, 2005 | 09:00 AM
str8racn's Avatar
Default Help! LOL
Okay, I have a 1993 Hatch with a 97 LS swap and a 95 LS ecu and the speedometer and odometer are not working. I am pretty sure the cluster has been swapped out and wonder if you all could give me a direction to go in to find out what the problem is. I almost bought the vehicle speed sensor yesterday, but thought I would ask before I spend the money on it. Is there anything I can look at on the engine wiring harness to be sure it is correct or something is not missing and needed, etc?
Thank you in advance and happy holidays!!
Old Dec 7, 2005 | 01:50 PM
sacicons's Avatar
Default RE: Help! LOL
if its not a bad wire (check the ground wire too), then its probably the sensor. do you have a friend with one that you could borrow? (should be an OBD2 donor)
DamageInc2405
May 19, 2007 10:28 AM
mombo
Sep 4, 2006 10:11 PM
Mr Mobsta Man
Jul 8, 2006 01:55 AM
CivicPower121
Mar 8, 2006 09:12 PM
AnakinKenobe
Mar 6, 2005 11:13 PM
