EG Swaps 1992-1995 Civics
Need info please for jdm b18c swap
Old Aug 16, 2006 | 09:35 PM
djhonda247's Avatar
Default Need info please for jdm b18c swap
Does anyone have a list of part #'s for all the mounts, brackets, pumps or whatever else I may need to buy for my swap into my 95 civic ex. Or a good website that will have all that information? Thanks
Old Aug 17, 2006 | 08:48 PM
djhonda247's Avatar
Default RE: Need info please for jdm b18c swap
Well just let me know the type of vehicle I will need to get my mounts from and I will do the rest from there. Are the mounts going to be the same as 96-00 swap?
Old Aug 17, 2006 | 09:55 PM
killajay's Avatar
Your question is very open ended.. what year is the motor.. 96 and up or.. 92-95... the mounts will be the same.. you will use the wiring from your ex.. you need the ECU.. you need to know if it is an OBD1 or 2.. your car is an OBD 1.. so if that answers some questions.. good if not ask in more detail
Old Aug 17, 2006 | 11:52 PM
djhonda247's Avatar
The motor is obd 1 and mt. I know the wiring details and I have the ECU. My question is about the mounts? What mounts do I need as far as stock? Something like 96-97 sol si a/c compressor mount and what are the others? Maybe also a related link to buy them all at a low cost.
Old Aug 22, 2006 | 07:36 AM
95civicDXXX's Avatar
you can find motor mounts on ebay.com for the B series swaps for cheap, and just about as good as hasport/avid. OR even cheaper would be to use the motor mounts from an old del-sol DOHC vtec model (may need to recheck that)
Old Aug 28, 2006 | 05:25 AM
civicracer94's Avatar
ORIGINAL: djhonda247
just did this swap yesterday on a friends car ok sence you have a ex (d16z6) you can use your stock upper driver mount and your top tranny mount and your stock rear mount but you will need a 94+ integra rear mount bracket.the front bottom ac/mount will need to be from an integra aswell as the front tranny mount dont wast your money on the hasport you already most of the mounts you need
Slazer
ED-EF Swaps
Apr 26, 2016 07:42 AM
legal
Jan 26, 2008 09:35 PM
swindy
Jan 23, 2008 06:46 AM
95 Civic B16A
Mar 18, 2006 11:40 PM
roc_sky
Feb 26, 2006 07:45 PM
