EK Swaps 1996-2000 Civics
B16a ek swap
Old Aug 30, 2011 | 01:20 PM
1997civicEK's Avatar
Default B16a ek swap
Hi guys this has probaly been done before but can some on please post a b16 a swap into an ek sedan please
B16a*
Old Aug 30, 2011 | 01:41 PM
Have you searched? You are right, this has been covered numerous times and should be fairly simple. Do you have any specific questions? Something you are stuck on?
Old Aug 30, 2011 | 10:45 PM
Well I know i can use my mounts that are in my car now. Would it be better if I put in better mounts? Also I don't know how to wire tuck
Old Aug 31, 2011 | 05:24 AM
Please search and use google.
Old Aug 31, 2011 | 10:30 PM
Shandles's Avatar
if the engine you have in there is the stock engine, then no, you cannot use those mounts. You need to use the search bar. B series engines have been swapped into EK chassis more times than you can even being to fathom.
Old Sep 1, 2011 | 06:14 AM
Actually, D and B series mounts in the EK (possibly EG's too) are the same except for the rear mount bracket which is bolted onto the engine. The one thing to watch out for is the 3 post driver mount which is commonly found on Integra motors.
OP, do some research, and let us know if you have any specific questions afterwards.
Old Sep 1, 2011 | 05:28 PM
Shandles's Avatar
really? when I've read about people swapping in B-series, I always assumed they needed to use mounts from a 99-00 SI... for obvious reasons. I had no idea the D and B mounts were the same. huh, well you learn something new everyday.
OP, it doesn't really matter. I'd replace the mounts anyways because I always hear about people busting stock mounts, especially if they go turbo or run any kind of real power through the engine.
Old Sep 2, 2011 | 06:16 AM
Does anyone have any 99-00 si mounts they have for sale? Or an ex wiring harness?
Old Sep 2, 2011 | 07:52 AM
Classified posts are not allowed outside of the appropriate section. You must have 25 useful posts in order to access that section.
Check eBay, or go aftermarket. As I have mentioned, the mounts IMO are the same. The only difference is the rear mount bracket which should come with the motor, so buying SI mounts would be pointless in my opinion.
crx9191
Jun 7, 2007 02:37 PM
cadman421
EK Swaps
May 11, 2007 12:47 AM
Hot94vtec
Jan 19, 2006 07:57 AM
LEVIII
Oct 18, 2005 01:31 AM
Mossy
EK Swaps
Apr 19, 2005 07:52 PM
