EK Swaps 1996-2000 Civics
d16 engine to b16
Old Aug 10, 2004 | 03:25 PM
dmsteele92831's Avatar
Default d16 engine to b16
I'm only sllightly familiar with engine work, so this might be a dumb question but here goes. If I were to purchase a b16a dohc head that came with cams, valves, rockers, vtec solenoid, and valve cover, etc. is this possible to bolt on to a SOHC d16 block? Or is the b16 block different than the d16? (I know I'll need the distributor and intake manifold as well)
Old Aug 10, 2004 | 03:35 PM
importmech's Avatar
Default RE: d16 engine to b16
You would need the DOHC block and everything. Engine-wise almost everything is different, you even need the transmission for the DOHC engine, different axles and wiring harness as well. I dont know the whole list, but there are some sites out there that give you a whole parts list of what you need, I have an import tuner that explains it and provides honda part #s that you need to do the conversion and how to modify your existing wiring harness (if you have a DX model) to accomodate the Si engine, I will see if I can find it and scan the pages for ya.
Old Aug 10, 2004 | 03:56 PM
ohbiskits's Avatar
yea i dont think anything from the b series motors will fit the d series...or vica versa
Old Aug 10, 2004 | 08:18 PM
2000Si's Avatar
ORIGINAL: ohbiskits
that's correct. almost anything from one B series will bolt to another B series (with exceptions which I can't remember right now)
Old Aug 12, 2004 | 05:52 PM
Thanks everyone!
fastrecklessracer
Dec 31, 2007 02:44 PM
GotRice?99ex
Aug 11, 2005 01:15 AM
boost_kamikaze
Jul 23, 2005 11:00 AM
Roost3r
Jul 9, 2005 03:48 PM
silvercivicsrs
Jan 15, 2005 06:15 PM
