EK Swaps 1996-2000 Civics
what do you think about a b18c5?
Old Jul 16, 2006 | 08:56 PM
2000_civic's Avatar
Default what do you think about a b18c5?
i have 2000 civic Ex. i want to swap the d-series for a b18c5... but i dont know if i should...
what do you think
Old Jul 19, 2006 | 05:13 PM
ej6buddy's Avatar
Default RE: what do you think about a b18c5?
I think any kind of swap is cool, but if money and a bunch of headaches aren't an issue, then shoot for the stars. ( i personally like the b18c1) You might want to look at the k series (a crap load of torque), i've heard that the install is pretty straight foreward, but i haven't done one, so what do i know.
Old Jul 19, 2006 | 11:38 PM
sacicons's Avatar
the b18c5 is great, but its pretty expensive. if youve got the money, then go for it, thats a great motor
Old Jul 21, 2006 | 02:32 PM
ek2ner_knox's Avatar
whats different in the c1 and the c5 besides hp and torque? they still go in the same way and u could get a gsr in obd1, but if its a 2000 civic then its already obd2 which would make it easier to where u dont have to get the conversion harness as long as its a 98+ motor....i think you can use the stock mounts from the c5 too as long as u use a 99-00 civic si rear mount and u have to have a dohc del sol ac bracket and then some other small things
Old Jul 21, 2006 | 02:35 PM
ef4life's Avatar
the c5 is overrated if you think about it. it is a b18c block with a b16a head with factory port and polish, better na cams, and more compression. you could get a b20 a b16 head better afteramarket cams and forged internals and a good tune, you WILL make more power and have a good amount more torque.
but if you want to just swap it and forget about internals then the c5 is the way to go, most hp for a b series and people would drool over it.
Old Jul 21, 2006 | 02:38 PM
ef4life's Avatar
or get a b18 and a stock gsr head and boost it. gsr's have good cams to run with a boosted engine, and an ls tranny has the longer gear ratios needed for a turbo engine, and they are cheaper and easier to find than a gsr or type r tranny.
Old Jul 21, 2006 | 03:43 PM
ya...c5 compared to b20...ls/vtec isnt gonna be as reliable as a c5 with bolt ons
Old Jul 21, 2006 | 05:38 PM
pWnEdU's Avatar
The B20 you guys are reffering to... is that the same as a K20?
Old Jul 21, 2006 | 05:49 PM
ef4life's Avatar
b20 is out of a crv, same family as a b16, b18 etc
Old Jul 21, 2006 | 06:35 PM
pWnEdU's Avatar
How would you compare the b series to the k20? The k20 is out of a type r civic isn't it?
