1993 D15B7 Head Gasket replacement
Old Sep 21, 2011 | 08:28 PM
srdaniel's Avatar
Default 1993 D15B7 Head Gasket replacement
So after sitting for a long time I thought I'd finally replace the blown head gasket in my 93 civic dx. However after lapping the valves, getting a new head gasket, I noticed a gap between the sleeves in the middle two cylinders (see pictures below). I'm thinking this gap isn't supposed to be there. The gasket I got is 4 sheets of metal. Should I try putting it back together anyway and see if it runs ok (who knows for how long) or is this the end of this block?
Old Sep 23, 2011 | 11:31 AM
droopy128's Avatar
would not recommend reinstall, move on with another block/motor..
Old Oct 7, 2011 | 10:35 PM
mpklkj's Avatar
you can try and fill it with some stuff that napa has that will fix it i forget what it is called it's like a type of glue small clear bottle strongest type they have but that might temporary fix the prob. i would just get a new block. get your head checked to see if it's worped.
Old Nov 8, 2011 | 09:04 PM
srdaniel's Avatar
The new MLS head gasket seems to be working just fine. Pressure is maintained (for now). I'll let you know in another 3-X months if it blows out.
Hanoihancock
Jun 3, 2012 01:14 PM
drakkon
Feb 2, 2010 01:21 PM
slade8
Dec 6, 2009 06:23 PM
civicpimpinsc
Feb 1, 2006 10:36 AM
civicpimpinsc
Jan 7, 2006 07:58 PM
