'93 Civic LX Engine Swap
Old May 2, 2007 | 03:48 PM
ksizzle89's Avatar
Default RE: '93 Civic LX Engine Swap
If you want something fast i would go with a B-series engine. I am considering doing a swap for my 93 civic DX. Good choices are B18C1-178 HP,B18C3- 195 HP,and B18C5- 195HP. they can cost high tho. Another good alternative is the B16A-160 HP. or try using a B16 block with a B18 head. strong engine which should handle boost well. I'm in the same boat as you and am trying to do a swap. I've been doing a lot of research
Old May 2, 2007 | 08:35 PM
Impreza WRX's Avatar
If you feel like really going over the top, there's always the option of the K24 from the RSX Type-S, but that requires quite a bit of shopping for special parts...
...but either way having a titanic engine in a small car is always lunacy...
...and yes, I'm the Jeremy Clarkson type person that always adds "MORE POWER!!!"
Old May 2, 2007 | 09:36 PM
k_dogg70's Avatar
thanks for the tips, a lot of info and research to be done. but i appreciate all the input. I wanna start a new post please check it out. i would like as many people's input as possible!
Old May 6, 2007 | 07:33 AM
k_dogg70's Avatar
any other suggestions
Old May 9, 2007 | 03:15 PM
k_dogg70's Avatar
anyone heard of a f23a1 swap into a civic? i think i read about a f22, but i could not find anything about f23. thanks
Old May 10, 2007 | 10:04 AM
mclane93's Avatar
I am doing engine swap into my 93 civic lx as well, i thought Id let you know that i am going to go with a b18b block and a v-tec head off of a b16. This allows you to have a b18 v-tec with lots of power. If you want more than 200 horses than i would suggjest sleaving the block. this give alot more strength to the cylinder walls, it will be able to handle closer to the 500 horsepower range then. The v-tec head is not very hard to wire, if you want touse this headI will walk you through it. Good luck man.
Old May 10, 2007 | 02:58 PM
k_dogg70's Avatar
thanks mclane, i'm still in the works of researching everything. but now i have another way to go. i'll hit u up about wiring thevtec. thanks again
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
