93 octane safe? fuel cleaners? octane boost?
Old Oct 10, 2005 | 07:59 PM
mill$civic's Avatar
Default RE: 93 octane safe? fuel cleaners? octane boost?
im not saying i believe this is true or anything..but when i had my old sunbird, i asked if i should use some cleaner ,and they said not to because if you never used it the whole life of the car, there will be so much guck or whatever there, that it will try to clean it and it will get even worse...
Old Oct 10, 2005 | 09:41 PM
sacicons's Avatar
that can happen, that it frees up some of the buildup thats in the motor, and it can get stuck in bad places. i say go for it, but drive hard right after to clean it all out.
Old Oct 11, 2005 | 01:30 PM
civicexracer's Avatar
alright, thanks guys. u've been alot of help!
Old Oct 11, 2005 | 04:26 PM
riceburner700's Avatar
ORIGINAL: mill$civic
that is what happened to me and now my engine knocks a little bit after i take off, if you are going to use it make sure you constinly use it dont just put it in once like i did
Old Oct 11, 2005 | 11:25 PM
sacicons's Avatar
maybe start out with a 1/4 bottle, then on the next tank use half, then the next tank use 3/4, then finally a full bottle. that way it will only break it up a little at a time.
Old Oct 12, 2005 | 04:21 PM
2000Ex's Avatar
I heard Lucas was the best, is this true?
Old Oct 12, 2005 | 06:30 PM
neon3kgt's Avatar
im in a GM school right now, and they say not to use fuel additives, it eats rubber. and little chunks of crap can clog your injectors. that would be a 300?$ fuel service that you might not have needed, if its cloged, you will have a missfire, fix it if its broken.
Old Oct 12, 2005 | 08:43 PM
sacicons's Avatar
hence me using MMO, it refreshs rubber, and very slowly cleans the deposits, as well as coat the entire engine with a very fine coat of oil, so it will help fight rust and buildup.
Old Oct 13, 2005 | 04:37 PM
trevorb05's Avatar
yeah dont use that s***y cleaner just send it to a gm dealership and ask them to clean it for u .....my bro is a mechanic and he brought the stuff home and cleaned my throttle body, intake, and injectors and man its a big diff the **** they use is the best try that!!!
Old Oct 13, 2005 | 05:42 PM
Kappa22's Avatar
Yeah... take your Civic to the GM dealership and watch them scratch their heads for 6 hours.
