97 civic lx vtec help
I put a Vtec in my 97 lx,
Im not sure what year the head came from but im thinking its from a 95
The distributor dont fit!!! can i just buy a 95 distributor and switch out the plugs?
Also i read that there is a oil injector in the block that i should have took out when doing a mini me swap is this true?
https://www.hondacivicforum.com/foru...ead.php?t=3683
http://www.jdmuniverse.com/forums/ho...-write-up.html
vtec not VTECH unless you seriously do have a phone in your car and looking at the stuff you got in it its entirely possible
Good thing for the edit option!! Anyway back on topic..
The old head was bad so i got the 95?96? vtec, The distributor is to big,, If i get the right distributor for this head can i re-wire the distributor plug?
I have the gray all in one plug [97],, i think i need to wire in the dual plug type [older].
The wire colors are the same it's just the coil has its own 2 wire plug..
snotsmear
Sep 12, 2006 02:37 AM
