activating vtec after swap
Old Oct 28, 2007 | 09:43 PM
Shawkab's Avatar
Default activating vtec after swap
Swapping a d15b7 with a d16z6 im just wondering if there are any detailed instructions on doing this anywhere?
I have no idea what i'm doing so all help possible would be awsome, I have the computer for the vtec.
Old Oct 29, 2007 | 12:16 AM
EF3 TEAM EOS's Avatar
Default RE: activating vtec after swap
if your swaping a vtec motor or head into a car not stock with vtec here are some opitions
vtec ecu with the vtec wireing harness in this case with the z6 you need a p28 and there alot these days about 100+ plus you need the vtec wireing harness witch is like 25+ so all togeather about 125+
or if you dead broke a toggle switch works grate flip on after you get to the proper rpm range witch is like 10 bucks
or msd rpm switch witch is about 110 bucks all togeather for the switch and rpm pills but it is very easy to hook up
the vtec ecu and harness is alot harder to hook up but it has alot more benifit in the end cuz p28; are very nice ecu's when it comes to chipping
Old Oct 29, 2007 | 12:19 AM
since you got the ecu but you have no idea wat your doin pay some one to do it but you will need the vtec harness
or sell the ecu for and buy msd rpm switch witch comes with instructions that make it simple to were if you can read then you can hook it up
Old Oct 29, 2007 | 06:56 PM
t34me's Avatar
or you could just plug in your p28, then wire up 2 simple wires to the oil pressure switch and vtec solenoid and save a lot of money. There are wiring diagrams for p28's all over the internet, just search.
Old Oct 30, 2007 | 04:00 AM
amg6975's Avatar
ORIGINAL: t34me
Yeah, no need to redo your whole harness.
Old Oct 31, 2007 | 06:28 PM
Shawkab's Avatar
Ok, thanks alot.
Took me forever to find some good instructions but I think I found some..
Here are the diagrams I found if anyone else wanted them..
http://www.d-series.org/forums/showthread.php?t=23202
Scroll down a bit..
new2honda
Aug 21, 2014 05:49 PM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
projektcivicturbz
May 9, 2007 01:36 PM
abra0101
Jul 23, 2006 08:47 PM
