ARP Headstuds.
Old Aug 16, 2005 | 06:10 PM
Pete's Avatar
Default ARP Headstuds.
Ok. Im going to order some ARP headstuds so i can prevent my headgasket and oem studs from breaking under the "lifting" if the D16 when its boosted. How hard are these things going to be to install? Ive never take then top part of the motor apart. Is this a possible DIY?
Old Aug 16, 2005 | 07:22 PM
ngoti 8tor's Avatar
Default RE: ARP Headstuds.
You might wanna replace your head gasket while you're at it. The new head studs are quite easy to install, just make sure you torque them properly and in the correct order.
Old Aug 16, 2005 | 09:40 PM
LEVIII's Avatar
Do you have a Chilton?
Old Aug 16, 2005 | 10:51 PM
sacicons's Avatar
you WILL want to replace your headgasket. you really shouldnt reuse an MLS headgasket. but they should come with some sort of instructions. you torque the studs into the block with the head off, then slide it on over them, then put the nuts down on the top.
Old Aug 16, 2005 | 11:12 PM
XCM828's Avatar
I've been doin my research too, and I'll probably also be getting those...
Old Aug 17, 2005 | 09:02 AM
Pete's Avatar
ORIGINAL: LEVIII
haynes.
SO this isnt such a hard task to tackle?
Old Aug 17, 2005 | 09:07 AM
ngoti 8tor's Avatar
ORIGINAL: pcupo12
No, it's not tough at all, you can do it.
FlipHKD720
28
Dec 16, 2010 08:47 PM
bcrichguitars
May 7, 2008 06:08 AM
dave_57204
Mar 1, 2008 08:49 AM
dave_57204
Feb 25, 2008 10:31 AM
didder
Aug 31, 2007 11:03 PM
