B-18 Block
Wut's up. My name is Mark and I'm new to the site. I drive an 98 CX Hatch and currently building a motor and
I have a couple of questions.
I bought a b-18 block from an 88 acura integra and was wondering if a head off an 98 gsr would fit the 88 block?
Any suggestions or comment would be appreciated.
Ok
1st you need aftermarket rod bolts
2nd you need to plumb the block for the oil passage to engauge vtec
3rd you need a ecu chipped to tune with or you need aem ems.
4th you need a transmission with shorter gears to take advantage of a all motor setup.
I suggest you just get a nice set of pistons, rods, rod bolts, head studs and cams then boost with a turbo kit.
tombakers
May 4, 2008 05:23 AM
Lost
May 2, 2007 10:52 AM
jo7man4
Jan 27, 2007 01:13 PM
